If you get a receipt from tyre place have a look and it'll probably say somewhere that you need to check the wheel nuts after 20 miles to make sure they're tight, that'll to make sure the studs/bolts haven't sheared from overtightning
Only time I've struggled to change a wheel was on 2 year old Citroen - the spare wheel carrier underneath had rusted solid and I almost gave in before it started to move.
used to go across from work to a chippy on Leeds Road in Bradford for lunch . . . very nice pleasant lady used to lick her fingers to get a good grip on the next clean hygenic food paper . . . sometimes the damp bit had dried before your chips landed on it . . .
had to extend it with a scaffie pole and they came off with a loud crack . I always put copperslip on them and the wheel centres after getting caught out a few times . some say don't do it cos they can come loose
rubbish I put it on all the nuts and bolts on my Norton and none ever came loose even sat at traffic lights on tickover and that makes your balls and false teeth rattle
. I was using a spider wheel brace but there was no way it was coming off. Like
] and watched.....#muchglowering
