Parm
Respect The Sound System
- Towcester
^^^ that’s pretty cool
years ago I saw this dude balancing rocks on Brighton beach. Not to that scale though
Reebar involved?
Probably some sort of electron/ionising beam therapy. Any deflection or vibration would obviously be quite serious.
I will be attempting to build a crank balancing machine in the near future
My dad showed me pictures of the foundations being poured for a linear accelerator at the hospital a few years ago, hundreds if not thousands of cubic meters of special boron concrete if I recall, don't remember exactly what the machine did but cancer treatment rings a bell.On the theme of solid foundations,, At a prostate cancer meeting a while ago. a guest speaker was talking about some new treatment machine needing a concrete foundation around a hundred feet deep!!!!!
Oooooh get you briiighton beeechyears ago I saw this dude balancing rocks on Brighton beach. Not to that scale though
Surely you'd have to calibrate the vibration senser with something that ran true?
Sounds well complicated.
Is this for a high performance engine, Bob? If so, are you going the whole hog & blueprinting it? [and since my nose is bothering me, what's it going into....]
I'm not sure that the mass beyond a certain point is going to help, what that point is I don't know at the moment (too early in the morning). The point about vehicles influencing the measurement is going to be relatively moot in this particular instance unless it happens to be perfectly in sync with the RPM of assembly under test / calibration.
I haven't looked into the logistics of a suspended unit but when we talked about building one for you (sorry, been assuming we're on Bob timescales here so had a few years to spare) the crank would have been on a solid base. Ultimately the accelerometers only want to be looking in one axis and it's looking for the biggest oscillation that is in sync with the chosen RPM, anything not in sync is filtered out.
My gut feel is that as long as the mass you're clamping the crank to its sufficiently bigger than the crank for you're purposes will suffice. Ultimately the compression and characteristics off each cylinder is going to affect the balance so you're not going to be able to fully balance it without it being in the engine. Even then variations in temperature of each cylinder / piston etc are going to affect things.
In summary, any extra mass in the base is going to help but there'll be a point of minimal gains after that.
