Anyone got one? Looking for how the headstock comes apart, and more importantly goes back together. Need to change the belt
Weighs more than I 1ton engine crane wanted when I tried to unload it... ended up jacking the back of the van up... taking the weight with the crane then dropping the Jack's and driving awayThat looks like a serious lump of compact steel
Now that's a nice one, I am prejudiced but I think this is the best lathe in this size.
Was wondering if these were ever sold in the UK.
https://onedrive.live.com/view.aspx?cid=547FE296ECFD561F&resid=547FE296ECFD561F!1822&app=WordPdf
Found and translated from a dutch site:
Incidentally, a belt is fairly easy to replace, you take out the rear bearing bush (which contains the ball bearings) (you can press it with 2 or 3 m6 bolts from the fixed head) and you have to loosen the left fork. then you have just enough space to put the v-belt around it.
It's if you're a little handy in half to an hour of work ;-)
