Hello
Clark 130TE blue about 27 years old, was welding ok - wire feed stopped [or partially!]
The motor tries to turn when trigger is pressed, thought it might be a clogged liner so tried without any wire and it will attempt but only only wire feed 10.
The relay operates, fan comes on
switches make no difference worse or better
@eddie49 asked if I got an arc at the tip - I do not - a mild, very mild static type flash occasionally but no weld and this is to cleaned metal subject - I even broke several welder rules probably and tried direct to the clamp - nada....
where do I begin to start to fault find please - whilst I deliberate a new toy
thanks
I forgot to add its totally standard and has not been modified wiring wise, its had liners and a replacement standard torch once
thanks
