ScottinColorado
New Member
Hi , new and like the site, lotta info!
I have a CLarke 150 EN and wanna change the tip as I am repairing the frame tails on my 1980 CJ5 Jeep and my welds were getting better but now the welder is sticking and the wire feed is groaning and I suspect the tip. I have had the welder for some time , bought it from a buddy but only played with it till now. I am using flux wire and building 10 inch long "shoes" out of some leftover elevator mounting steel angles that I think are 3/16 inch thick . Have cut the steel to make a horseshoe of sorts to insert into the chopped away section of the lower frame that was so rotted that the spring hanger was punching its way upward into the rust. The good part of the upper frame tail serves as my benchmark and the shoe fits inside perfectly . Big project for my welding ability but as I said , my welds were getting better but now the feed is acting up . I can unsrew the whole torch tip sheild bit it won't pull off over the tip. What am I missing here for this maintenance issue ?
Thanks !
Scott
Thanks !
Scott
