View attachment 232819 View attachment 232820 I used a metro driveshaft - the creator had welded a bolt to the original.
That reminds me - I need to screw out the broken clamp bolts on the toolpost. Long term I would like to fit some quick change tooling, but damnit - it's expensive.
I shortened some ford ones, when I built this trike. They were hard as hell on the outside, but quite soft once through the outer layers, awful to machine.
Yeah I machined down my reliant ones when i shortened mine I know what you mean about the machining though!. I just need to make my front spindle as my front forks are almost 11" wide and will be using a 1" bearing rear Harley wheel up front so nothing stock will fit. I do have a pair of TD5 half shafts at home though which are about 30mm thick so i reckon they could be re purposed.
Some are very much like this, some are hard very deep (vauxhall), some (Leyland mini, metro) are soft enough to machine without coolant, just a squirt or two.
I would have no issue using a metro shaft again, or anything as long as it isn't too hard.
Get on with it!I think I will give it a go and see how it goes. I have a thread on the trike doctor forum not updated since like January last year as I have only just got back on it but you have replied there a couple of times! hoping to push on with it now!
