Brad93
- Essex, United Kingdom
Got a weird issue.
I can’t seem to cut this dxf. I just cut a similar shape with one slot, created exactly the same way in fusion, And it cut it fine.
I then try to cut the same size shape but with three slots and it gets stuck after cutting the first slot, I then have to see t the next line and press ‘Run GCode’ again. It then cuts the second slot and the third slot, but pauses and hangs again at the end of the third slot. Both times the line it gets stuck on is ‘M05’.
Any ideas? You can see I had three attempts before I figured out I could select the next line and click run gcode again.
https://youtu.be/yM9VLl-V1Hg
I’m saving a DXF from the sketch in fusion, then importing it into SwiftCAM (Libellula) and then importing the gcode into SwiftCut (Mach4)
