Chrisgixer
New Member
- Brackley
Hi
....newbie first post.
As title I need this fitting I think.
https://1drv.ms/u/s!AoLdvKhsv6QskClO26BrChTx6UzR
it holds the liner in the torch when screwed in. Anyone know where to get one? What it is? What it’s called?
I can’t find it on line although my search terms are probably inaccurate
It was welding fine then started to play up with wire welding to the tip, then there was a banging in the machine I presume where the drive wheels were skipping or jumping then it just stopped welding. The wire speed gradually became maxed out. Checked the wire in the torch and it was very stiff so new liner ordered. 4mm dia metal sealed liner. Old one was plastic so either cheap or it’s been used for softer wire..?
anyway anyone know this fitting? Looks generic but I can’t find it
ta
oh ps, I had trouble with the wire speed dial not responding long ago. It had a dry joint on the dial to the board on one of the prongs. I wonder if the restrictive liner caused things to heat up and that affected the solder in the joint?
ta
I was thinking last night if that goes in the torch end how will the grass escape etc... Oh well. How we learn
