all I can say is if u aren't happy doing it don't. if u are happy and confident carry on
A pretty good rendition in my opinion. I know Sean through another friend in New Bradwell.
If you stand it up and fill it with water it is full of water has to be tip it out it is full of air has to be. where do the pockets of propane hide. Some one once mentioned that is soaks in to the steel .So how is the gas retained in the bottle .OK I’ll bite. You fill it with water and cut it while full?. If you empty then cut it, there is the possibility of a small amount of remaining gas building up again inside the bomb casing. I am familiar with the stenching agent which is not dangerous, I mean small pockets of liquid propane can also be left behind, even after flushing with water.
There is no "recommended" way of doing this as it is seemingly illegal .
As far as i am concerned if you need to ask DONT DO IT
Yes.
I have just cut a cylinder . No way would i video that . The do gooders would have a field day sitting behind there screens bollocking mePerhaps you could find out where pockets of gas hide? And then do a video
well seeing as though propane is heavier than air it would be at the bottom if u filled it with water the waters heavier so the gas would go to the topPerhaps you could find out where pockets of gas hide? And then do a video
not u but others say the steel absorbs some of the gas its all a load of rotall I can say is if u aren't happy doing it don't. if u are happy and confident carry on
We're talking at crossed purposes, I think. Sean was in the remake and is the chap behind the counter.
Only 1 tablespoon of evaporated acetone caused a lethal explosion
Suppose doesn't seem much as a liquid but forget what its like as a gas.
Sean is not an O'Dell. He played the part of Ronnie Corbett in the remake. Capish?
