MattH
- Cornwall
I've had to gear down my drive on my CNC plasma build as I was struggling to tune my servos tight enough for a clean cut, I also wanted to up my acceleration.
To this end I had a set of 5:1 low backlash planetary gearboxes to suit the servos I am using which I have now fitted.
Before the servos were driving the ballscrews with a 2:1 toothed belt reduction i.e. 24T on Servo and 48T on screw and the screw had a pitch of 25mm per revolution.
This meant that one revolution of the servo amounted to 12.5mm of linear movement.
I have now added the gearboxes but at the same time changed the belt reduction to 1.33:1 i.e. 36T on gearbox and 48T on ballscrew.
This means that 1 revolution of the servo amounts to 3.75mm of linear movement.
All this is well and good until you factor in the 10,000 pulses needed to turn the servo 1 full revolution.
This means that the pulses per mm in the software ends up as 2666.66 reoccurring.
This fractional number then causes compound movement error.
To combat this there is an option in the servo drives for electronic gearing i.e if you put a gear number of 2 in then instead of needing 10K pulses per revolution it will only need 5K.
Further to this you can add a denominator to allow for fractions i.e. a gear number of 5 and denominator of 2 would give a electronic gear of 2.5 so 4K pulses instead of 10K.
Anybody still following / reading?
Good.
So my total drive reduction with a 5:1 gearbox and a 1.33:1 pulley reduction is 6.66:1 which drives a 25mm pitch screw.
So 10,000 pulses * 6.66 = 66,666.66... (pulses) / 25 (screw pitch) = 2666.66...
2,666.66... Pulses per mm is a bad number.
If I put a Gear number of 100 and a Denominator of 75 into the drive I get an electronic gear reduction of 1.33...
So 10,000 / 1.33... = 7500 pulses per motor revolution.
7,500 pulses * 6.66... (gear ratio) = 50,000 (pulses) / 25 (screw pitch) = 2,000
2,000 Pulses per mm is a good number.
All this means that my maximum speed has dropped from 37.5M/min to 11.25M/min.
The top cutting speed of my Hypertherm 45xp is around 8M/min on 1.5mm steel so plenty of headroom for that and I have solid and tight acceleration of 3000mm per second per second.
Can anyone see any glaring error/s in my math?
Good.
