Jacktegla
- Denbighshire
Or could I buy this torch then take the cutting head off and put this rosebud tip on it ?
Is that even if you're using oxigen with it or just solely on propane ? I am using either oxy acetylene or LPG gas with compressed oxigen, didn't feel much difference...Acetylene tips dont like propane
The propane tips have a ring of smaller flame jets around the outside
Parm, which torch are you using for brazing?
Would you use the welding torch for heating up metal
This is what i use
https://www.thewelderswarehouse.com/cgi-bin/sh000001.cgi?WD=oxy torch propane&PN=LD-oxygen-propane-torch.html#SID=424
in use at 11.30
I'd look at these. https://chorleybottlegas.co.uk/shop/welding-gas/oxygen-20-litres/
No stupid fees or charges and a full refund on the "Deposit"
How BOC can use the term deposit is beyond me..
From my experience the hose connections remain the same, The nozzles are what you change depending on if you use Acetylene or Propaneso Are all of the torches for oxy acetylene are interchangeable with oxy propane ? And are the fitting to fit to the hoses all 3/8 before I go buying torches that won’t fit on hoses.
I’ve just looked at the one doubleboost reccomended and that says it has 1/4 bsp connectors, so would you go for that one or use the bigger one they have 3/8 pipe fittingsFrom my experience the hose connections remain the same, The nozzles are what you change depending on if you use Acetylene or Propane
The gas hose uses a left handed thread
Are most regulators 3/8make sure you have 1/4" or 3/8" BSP threads on everything, it's easy to get caught out.
I think my stuff is all 3/8"BSP IIRC, and I'd mistakenly bought some hoses with 3/8" inlet, 1/4" outlet.
orange for propane red for acetylene blue oxygenThink you need propane specific hoses,others just rot.
