Shox Dr Chief Engineer to Carlos Fandango Messages 17,986 Location East Yorkshire May 10, 2020 #1 Any suggestions as where I can source a replacement for the wiremesh, in the sunbeam carb. OD 4" ID 2" D 1.5" If I can get one less than 4" dia (95mm) then I can reuse the mesh cover Needs to be reusable
M mr haynes Member Messages 1,300 Location Scotland May 10, 2020 #2 https://www.knfilters.co.uk/ Shows their range. Pipercross for foamy filters https://www.thepipercrossshop.co.uk/ https://www.thepipercrossshop.co.uk/filter-socks_c278851_281235.htm
T tom2207 Member Messages 7,998 Location uk northern ireland May 10, 2020 #3 should be loads on flea bay ,,, pancake filters if you have the lid you can buy the foam ,, but i like a second layer of mesh on the inside of the foam , to make a sandwich , ive seen the foam break up before today.
brightspark Member Messages 41,585 Location yarm stockton on tees May 10, 2020 #4 whats stopping u buying the mesh and making your own https://www.ebay.co.uk/itm/STAINLESS-STEEL-WOVEN-WIRE-MESH-filter-grading-sheet-/251198345904
500e Always buy fire insurance a flood is a hard start Messages 9,378 Location South West May 10, 2020 #5 https://www.southernfilters.co.uk/products/mesh-wire-frame-filters/
Matchless I started with nothing, still have most of it left Messages 3,005 Location Essex UK May 10, 2020 #6 MGA uses something very similar, I fitted conventional filters inside my MGA housings in 1974, still in there, must check them some day!!
X xstian Member Messages 193 Location Norfolk May 10, 2020 #7 Have you thought about making one from foam?
8ob Member Messages 14,374 Location Nescient in the vale May 10, 2020 #8 Not sure what they call them now but we always referred to them as a pancake filter. I am sure you could modify the guts of one to fit the bike. Edit, Tom has already mentioned it. Bob
Rannsachair Forum Supporter Messages 4,511 Location Lochgilphead, Argyll, Republic of Scotland May 10, 2020 #9 https://www.stewartengineering.co.uk/viewPart.asp?id=934 too expensive?
T tom2207 Member Messages 7,998 Location uk northern ireland May 10, 2020 #10 8ob said: Not sure what they call them now but we always referred to them as a pancake filter. I am sure you could modify the guts of one to fit the bike. Edit, Tom has already mentioned it. Bob Click to expand... loads on flea bay from about a tenner ,, not dangerous money. I typed in '' pancake air filter''
Shox Dr Chief Engineer to Carlos Fandango Messages 17,986 Location East Yorkshire May 10, 2020 #11 Thanks for the replies, I’ll filter through them
