MajorPayne
Heya guys and girls
This is a bit of a silly question but I've never done this before and I wont be doing this work for a while yet but I'm trying to figure out the tooling required so I can equate for it in the near future.
See I'm going to be building some road bicycle frames using three types of materials depending on the customer but in the past most of this kind of work was already undertaken by other companies, so we had the parts provided and well, welded them into what you would call a frame.
The three materials I will be working with are:
:Stainless Steel
:Aluminium
:Titanium
Apart from the materials the sizing is about the same on each bar a few little things like length of frame, here in the image[far bottom] you will see the bottom bracket and it has internal screw threading from reading this is completed using a tool called a 'tap' the 'die' is used for external threading, now from searching around these 'taps' & 'die's' which are in common usage seem to be more geared towards M style nut & bolt sizing which I don't find funny because their quite common.
But with the work I will be undertaking the pipes diameter is 40mm and the wall on the 308-steel is 3mm, here's the easy part after all the junk I've written so far[getting to the point] does anyone know how I would go about copying this process? The tooling required?
I was thinking, using a Lathe with the 'tap' of required size is my thinking process off by some marks? Leading my brain up the wrong road here?
All help would be awesome and as I've mentioned I don't have the tooling at the moment because first I need to find out the proper process to get the job done and it's preparations for the future.
Very kind regards,
MajorPayne
P.S: Heres the image of what I am going on about if I've lost anyone.
P.P.S: here's a link to some of my other things I've been doing this week or so the tinypic site is new to me and it's all testing as I need a more online place to put some of my stuff and it's good to be able to upload and then share things with others
http://tinypic.com/2mpjzpsp
:Stainless Steel
:Aluminium
:Titanium
Very kind regards,
MajorPayne
