No never seen that must be a new design as I certainly never came across it when I was thereHave you seen the ESAB Prima range? I may get one of those next...
https://www.esab.co.uk/gb/en/products/ppe-accessories/accessories/eco-holder-prima.cfm
I only need a 200 amp version and it looks like it uses the same clamp style as that GYS 400/500 amp I posted pictures of but being 200 amps it should be smaller/lighter.
Oddly enough I find the heavier ones feel more stable, if that makes sense.
I know what you mean. Something with a bit of heft to it feels more stable.
The clamp style (crocodile and V notch) could be refurbished , using a triangular file an "milling" the contact surfacesHey guys I've pretty much used 70 % of electrode holders.
Best for me is
Stinger v pros holds rods up to 6 mm tight and you can bend the rod to any angle down side is f u catch the spring on something it will arc out
Next is crock style a decent one like my tweeko holds rods nice but find getting big rods in the grove plus my Paton had a nice crock style. I have the Japanese one on my inverterfusion which is ok but it's old so doesn't bite to well have to bend the rods round the outside edge of the Stinger
Then 3rd is the twist ok but no matter how hard you tighten down the rods never stay in there although this is the cheap ones I have a expensive twist one some where but I never really got on with them . I used the myking a few times ok for small rods but finding the hole is a pain some times
My preference is my preference and my opinion it is down to the welder I'd recommend trying out as many as possible so you get a feel burn a box with each in the most common sizes and you will find which you will prefer
Best for me is
I have a couple of Esab twist types, I like them but only one of the holes works properly on both of them - the 45deg hole can't get the rod seated properly... maybe just me.
The 200a one can only just fit 3.2's into the holes, the 400a one can fit much bigger... if this is any factor.
I've came around to like the Bernard short stub type is better, even the cheap knock offs. Never had any problems with them.
Hate the spring clamp type. They never feel secure, to my mind. They also usually have more metal exposed... so possibly more risk of stray arcs.
I agree on the heft side of things with stick welding. A slightly heavier stinger "feels" better. All these 400 or 600 amp rated holders... let's be honest, most of us will NEVER use more than 160 amps anyway, but it's more about this:
....if it doesn't work out I'll take a look at Bernard cheers.
