spaffmonkey
- Northampton
Good evening all.
I've recently purchased a little old Clarke 100e mk2 mig welder for tinkering around in the shed with my son instead of lugging my work welder home.
I've never used a hobby torch before and as it requires a new swan neck I took the torch apart and have a couple of questions.
1) should the wire feed liner end where it does in picture or should it go further into the brass block?
2) the thin bit of metal that the trigger presses against when the trigger is pulled in the metal touches the black wire's connector. Is this normal or should it be covered?
3) as the swan neck needs replacing due to end being broken can you get a replacement swan neck that will take normal MB15 consumables?
