would tell youThat’s great that you’re getting there it will be miles cheaper to get a pub co2 bottle but it’ll mean you have to get a new regulator. The welder you’ve got has a gas solenoid so if you turn on the bottle then flip the wire feed roller off when you press the trigger you should be able to hear the gas coming out of the shroud. You should be able to weld 3mm ok on max 2 might just have to move a bit quicker but as I have said I’m not an expert give it a go and see how you get on. Graham.Thankyou to everyone, looks like I failed to do the obvious , clean the metal well. I managed to get a co2 gas bottle and tried the gas option with the electrode connected to the positive this time. I noticed this seems to give a better result for me. I think you guys would definitely reject the results, haha but at least I,m up and running now. Could I ask if the strongest setting on this welder max 2 , would this be too much power for 3mm mild steel. Also I've bought a co2 gas bottle and I have the correct value regulator ( bought it from clarkes ) how do you release the gas from the bottle, is it just released by turning the regulator knob up ?
Few things to check.
Check the "Return" clamp is on the positive side. If using gasless wire.
Is it gasless? Halfordss were know to mix them up.
0.8 is about as big as that machine will take.
The feed wires are marked 6 on one side and 8 on the other (Or 0.6 etc.)
Does the wire feed evenly?
Set it up, mid range and pull the trigger. It should drive out in an even manner.
If not, you need to investigate the drum, feed rollers, liner and torch. Lots of useful information on here about that.
Clean up your metal, looking for a bight shinny surface.
Angle grinders are good for that.
Then try to lay beads down on a scrap bit. Or.
Practise. Practise and do it again.
You need to know your machine.
It needs setting up.
When you are happy.
Chamfer the edges and tray again.
You have many issues on that weld.
You need to step back, enjoy a coffee.
Then work trough in a logical manner to find out what is wrong.
Hope this points you in the right direction.
many thanks for your adviceSounds like you're making progress, have you had a look at the tutorials for getting started? - link here
Thank you, at least I've got up and running now, just need lots of practise it seemsSounds like you're making progress, have you had a look at the tutorials for getting started? - link here
Hi davediy I got mine from a bottled gas supplier. They do propane,welding gas and cellar gas you can find these places if you look on google just make sure if you go somewhere like this that it’s pure co2 because some beer gas is mixed. I believe it’s possible to get them from your local pub, it’s worth asking. Graham.Hi graham, how do you get hold of a bottle of co2 gas.....sounds like a large bottle would be a lot cheaper than the little bottles I'm buying from toolstation.
Hey many eddie49 that's a great site. Thankyou. Do you know I've never known a more helpful forum site, cheers all.This supplier may be of some help, or at least shows what can be available:
https://yorkshire-co2gas.co.uk/welding-co2.html
( that was searching "York CO2 pub gas"
Regulators designed for "Pub gas" CO2 cylinders connect with a flat nylon seal held on by a female sleeve nut.
Yeah I’ve got a bottle of argon mix but it’s just ran out. When I first got the Mig I got a bottle of co2 but when I could afford it got the mixed gas and it’s so much better once the lockdown is over I’ll be able to exchange my mixed bottle. I would personally get a bottle of co2 if I was you as it’s the cheapest option then providing you are still enjoying your new found hobby get a bottle of argon mix at a later date. Graham.Thanks graham I'll shop around. Whilst I'm on, have you ever tried pure Argon....or even Argon 75% mixed with co2 25%.....which gets the best results in your opinion. Cheers Dave
Really, I looked on eBay and they are cheap ......so as long as the bottle is inverted (upside down) and connected to were the horn unbolted, your just the same . What about the trigger thing, on the top of the fire extinguisher ? doesn't that have to be depressed or something to allow co2 gas to flow ?If CO2 suits your welding needs, 'out of date' 2 Kg CO2 fire extinguishers bolt straight on to a standard regulator, once their 'horn' is removed.
They need to be inverted, or the reg. freezes up.
Cheap or free, depending on who you know. They contain the same weight of gas as about £100 worth of disposable bottles.
There's a Ebay seller doing them for £6: https://www.ebay.co.uk/itm/2kg-CO2-...398108?hash=item4da8cb9d1c:g:2xwAAOSwU7Jd~dA~
