Ashley Burton
- Northamptonhire
@roblane65 never cheap, Only cost you money!
...a brass threaded cap that retains a spring and a ball bearing...Can’t find any spares available...
Killed an orbital sander, spent ages removing the fluff from the Velcro plate, still firing disks like frisbees.
If you can measure it and draw it, someone on here will make you one.
I could possibly make my own, I have a lathe etc, I just have so many other jobs on at the moment. The only slight issue I could see is that it has a hex broached into the top.
Could a slot substitute the hex? Is it a male thread or female? For a male, you could start with a brass BSP pipe bung as they already have the hex in them. Take or find a picture showing the piece and we can advise.
If you get stuck, I have a rotary broach I've just made so you could send me the part and I'll broach a hole in it (as long as it's 3 mm, 4 mm, 5 mm or 6 mm AF!)
it went to pot . get itNot a tool, but flippin' annoying and not at all surprising:
Had to drill out a contact on an ancient ceramic light fitting.
Nipped up the fitting in the mill vice.
Guess what happened next.
Please feel free to add your own tales of woe or merciful deliverance from tat.
I've been busy at home over the Easter weekend lockdown and I've managed to trash a record amount of tools. I have replaced the front discs and pads on the car. There was one wheel nut that wouldn't budge. It must have picked up something on the threads as I use a torque wrench for peace of mind.
The 4" extension was attached to a 12" sliding T handle so there wasn't whole lot of leverage other than my not inconsiderable weight. I was using my foot on the T handle so I expect the forces weren't strictly turning true when the extension gave way.
The impact socket was attached directly to the T handle for the second attempt. This time the impact socket gave way when by pushing against it by hand. It's just cheap stuff that comes bundled with Chinese air tools. I have loads of bits and pieces like this so the job wasn't held up. The nut finally budged with help from a corded impact gun which I am starting to like.
I was tapping by hand when the cheap Chinese tap handle broke; this threw me and so I managed to shear the 1/2"BSW tap at the same time. The tap was very old and probably British but didn't show much use. I was backing the tap off at regular intervals. The second attempt on fresh material with a machine tap got the job done but it was very hard work. It's for a part on an old lathe.
Will replace these bits with better quality stuff when I run out of the rubbish.
When you are using an extension to take wheel nuts off, get an axle stand, jack the car till wheel free, put the socket and extension on the wheelnut, turn the wheel till the extension rests on the axle stand, and let the jack down, fit the breaker bar and crack the wheel nut. The axle stand stops the extension getting out of line and rounding the nut off! works every time!
Phil
The Bosch died.
Cooling fan came disconnected, lots of smoke. But it was working.
Opened it up.
A test repair.
But it didn't last, so on my way home I went shopping.
