^ My cabinet has a small breathing hole at the back. And as it's a syphon system doesn't have such high nozzle pressure.
The more research I do on blasting the more confusing it becomes.
I'm going to invent an all-in-one compressor, cabinet and pot system and clean up.![]()
^ Yep it has two holes. I linked to it on the second post on this page if you want take a squint at it.
I think I'll be ok with the 18cfm blower and that pot I'm looking at. Should cover all the bases and blast things I'm likely to get or want to tackle.![]()
I do a lot of Vespa & Lambrettas and my 14 cfm just keeps up with the work, and I recently added another (2hp) compressor which has helped a bit.
You'll be better with 18cfm, it may even get chance to rest once in a while!
I think you have set a new record - replying to a thread from 2008 - no wonder none of the links workhow much would you do in 5min with the 14cfm compressor, 2 X A4 page size ?
Which pot are you using
Looking into this myself, I have a few bonnets and body panels to do, I also have a 14cfm compressor
