Don't I know it!and another vote, great that it can be used in confined areas
I now have a SP master flaring kit and also a flaremaster II and they are great, although I’ve naturally I’ve had very little use for them since I sprung for them....
Need to double flare 6 brake lines, I’ve used the sp flaremaster2 in the past which is a great tool but just a bit pricey to make 6 flares. Can anyone recommend a cheaper alternative ?
At the end of the day it really does depend on how often your going to use said toolI fully understand what you are saying about the cost but you are talking about the difference between something that will do the job and something that is the very best hand hold unit money can buy for £80 more.
I would argue that if you are at the point where you want to make 6 brake lines then it's likely you'll do it again in the future.
I also realise that to many people £80 is a big investment.
If your in a workshop environment, Then 100% I would probably spend the extra as no doubt you would probably use the tool more often & the larger investment would be worth while
But with DIY usage I would just buy something good enough for the job. I rarely do that many brake pipes
Just looking at the lines I need to do and I think 2 of them are 1/4 inch and 1 is 3/16 so il need one than can do both
