davidjohnperry
a different breed
- yate/bristol
Some follow me on Instagram some don't but I've got a project that is going on I can either borrow it from work or buy my own from weldibility for 90 quid with 4mm carbons
My questions are I've got a few machines I can air arc off but I know it destroys the machines.
Would a migatronic LTE 200 DC transformer type run air arc the rods run max at 150 amps but it doesn't have 60 volts under load it's 25 volts open 90 volts this is the machine I would happily sacrifice my other machines I have
Is
Thermal arc on 300 multi process
Thermal arc 175 te
Paton 255 multi process
Inverterfusion 200 amps
Murex trade arc AC 330 amp I'd happily sacrifice this bag of but air arc needs to be dc
Lincoln ranger 250 engine drive
Lincoln sae 300 engine drive DC
These I don't really want to use if I can avoid it
Other than that I have a scarfing tip and oxygen propane which I can use if needs be
Is
Thermal arc 175 te
