CRS51
- Cheshire, England
Hello all, I am after some help/advice regarding the wiring on my generator.
It is a Flathead Ford V8 3 phase generator that was part of a field hospital.
I have had the engine running but as the wiring looks suspect I have removed the belts.
Is there modern control equipment that I can put inside the original control panel so to retain its looks ? I am after a voltage and current regulator.
I have attached pictures of the wiring diagram that is mounted on the side, thanks in advance
Chris
Chris
a fair few pto drive ones ive wired on farms have built in heaters for when not in use. a megger insulation test would be advisable as well
