Hi
I'm prepping my old 205 CTI for its respray I've been working my way round the front of the car removing the rust with various wire brushes, sanding discs and flap wheels etc.
however there are certain areas which have pin prick style rust pitting but because the panels are so thin i don't want to go too aggressive with the grinding and risk going through the metal. Therefore I'm thinking i probably need to use some kurust or the like on these affected areas.
Is it best to apply the kurust over and around the area, let it work for the required period then sand/grind back to bare metal leaving only the small pitted sections covered in kurust before applying my U-POL acid etch primer(or etch weld primer in the areas where i need to spot weld the new front panel on)
Cheers
Matt
Cheers
Matt
, the tesco's home delivery man thought i must be bomb making when i ordered 20l in our weekly shop one week!), but it did appear to stain the items once you took them out even when washed and dried and they got a surface coating of rust very quickly indeed i found.
