hotponyshoes
- Somerset. Uk
So i have got a marine vhf antenna.
I got given this as the cable has been cut off.
I do have the proper connectors and a coupler so I could just fit those and cover with adhesive heatshrink but that's going to be bulky and ugly so I would rather get it apart and fit a new length of cable if possible.
It looks like the mast is fiberglass and the base is plastic. I think it's been stuck togeather with epoxy?
I did think about cutting it off at the glue line then removing the glued in bit with a dremel but there is a sharp taper on the mast section so the bit that needs to go back in will be a very sloppy fit.
I did a quick google and it looks like warm sulphuric acid will dissolve cured epoxy but I think that might also dissolve the plastic base. Along with my hands, the brush, the workbench etc.
I am currently thinking of slitting the plastic base with a dremel cutting disc and seeing if I can leaver it apart enough to break the bond?
Any better ideas?
Any better ideas?
