slim_boy_fat
- Scottish Highlands
I will seek burnt motors like this to use the rotors as rollers for a benderThanks to @Mikey D, today I acquired a spare bandsaw motor:
It's seen better days, but it only took a handful of curse words to get it into this state:
Most of the screws came out either with a screwdriver or with mole grips, but you can probably spot the more stubborn one...
New bearings on order and the shaft has one end soaking in some hot citric acid (I'm doing one end at a time to try to keep the acid off the bearing mounting surfaces as that seemed a good idea):
I will seek burnt ones because using a good one for my project would be a wasteIt's not that burnt really. New bearings & some TLC and I reckon it'll run fine.
That's a drop scone.
And Joan Bakewell
supposed to be lucky if a bird crap-s on uA pigeon drop its letal load on my head
I'm going to have a shower
Next project Will Be an AAMGsupposed to be lucky if a bird crap-s on uI wouldn't have said so if it had been a seagull though and would have got some lead up its rear end
It's sign of a anti aircraft machine gun on my home roof
The wife picked up on a hint for a birthday present:
Aluminium pushrod tubes (I know I should have had a go at making them myself on the lathe).
So if I get time next weekend, will get fitted to:
That's a good buy, I was just under £80 for 20 square meters from Costco.I had better check my stock of grey floor tiles! I bought 50+ square meters at auction for £160.00, slowly using it in the workshop,
Yeap: already done thatyou probably know, but it pays to clean the points with some fine emery .
"humane" as in "fast kill" (bolt to head) not humane as in "catch + release".
i hate to kill things i'm not going to eat, but we haven't reached "rat on a stick" apocalypse levels yet,
i've had leptospirosis (i think!). I'm not going to risk it again, so they need to be gone.
