123hotchef
- Kent
will the nails fit? I have read they are different!Really. Well the nails will fit. Just the gas. Bit odd. Worth seeing if you can get gas cheap elsewhere.
Thought it was the gas connection. Wait onewill the nails fit? I have read they are different!
this is a 360 its the newer version, what does one clean and oil just so I know, I like to look after my toolsim350 i use are faultless every day and i have 3. Donate 30 mins every 2 weeks to them on a cleaning and oil service and they do return the favor in reliability. Trouble is i am a victim of my own shouts as i also service guns for about 5 or 6 other lads for them.
nah i only just got it lol, its only to build me new shed and to stud out a mates garage, maybe when the milwakee one comes out ill sell it but until then ill suck up the cost of nails and gasFull heads on the new one full price for you boyo
Sell it and grab a 350 for clipped heads
top and bottom O rings and the cylinder head including combustion chamber..there is a fine mesh filter at the top which you can clean with brake cleaner. Also the biggest con ever is the gas being out of date..there is no way a gas can deteriorate when old as its fully sealed, it just needs a bloody good shake to re-mix the butane with the lubricating oil which is blended into the gas canister.this is a 360 its the newer version, what does one clean and oil just so I know, I like to look after my tools
Ah. Just reminded me. Il have a load of the new style gas in the shed. Be a few years old mindtop and bottom O rings and the cylinder head including combustion chamber..there is a fine mesh filter at the top which you can clean with brake cleaner. Also the biggest con ever is the gas being out of date..there is no way a gas can deteriorate when old as its fully sealed, it just needs a bloody good shake to re-mix the butane with the lubricating oil which is blended into the gas canister.
how do i oil the o rings via a hole? or dissasemble?top and bottom O rings and the cylinder head including combustion chamber..there is a fine mesh filter at the top which you can clean with brake cleaner. Also the biggest con ever is the gas being out of date..there is no way a gas can deteriorate when old as its fully sealed, it just needs a bloody good shake to re-mix the butane with the lubricating oil which is blended into the gas canister.
was hoping it was the old style when i started reading your post..then read it properlyAh. Just reminded me. Il have a load of the new style gas in the shed. Be a few years old mind
for my gun is it?Ah. Just reminded me. Il have a load of the new style gas in the shed. Be a few years old mind
disassemble....youtube full of it mate so you cant go wrong,just go easy on the captive nuts when doing up the bolts on the top loader and moulded case as they don't need much to give you a bad dayhow do i oil the o rings via a hole? or dissasemble?
how many fires to a clean and oil is it? do i need to oil any thing daily like a air tooldisassemble....youtube full of it mate so you cant go wrong,just go easy on the captive nuts when doing up the bolts on the top loader and moulded case as they don't need much to give you a bad day
All depends on the working conditions but every 2 box of nails will be good..light oil very much like the old 3 in 1 machine oil..don't know if you can still get it but i use ATF and no problems at allhow many fires to a clean and oil is it? do i need to oil any thing daily like a air tool
Yes il dig en out.for my gun is it?
cool thanks
well i just picked up a 360CI wont be getting state side and the milwakee will be ages so this came up and I nabbed it now to find some gas and nails its different to the 350
mine is a framing paslode it fires normal paslode nails the same as the 350 and is also a first fix nail gun
as noted the gas is different to mine and all i did was swap the plastic pin to mine and the gas fitted into my paslode gun
