Screwdriver
Could somebody please knock up a little bracket for me please?
Needs to be circa 2 - 2.5mm ideally something like Zintec but mild steel would be fine. It's for a motorcycle instrument cluster bracket and will be welded to a headlight mounting frame.
Currently it's a Sketchup model but I may be able to adapt it to your CNC format of choice. Sketchup is not great at curves
so again, ideally, you would be able to import from a raster or illustrator graphic.
I was going to do this by hand but hole position is crucial and it needs to look OEM so I really ought to get this part made properly.
so again, ideally, you would be able to import from a raster or illustrator graphic.I was going to do this by hand but hole position is crucial and it needs to look OEM so I really ought to get this part made properly.
I even have some 2mm S/S. Postage could be a problem, only time wise
