angellonewolf
- bristol england
As above can the drain for a boiler be run out side on to grass or does it have to go to a drain
put it in to the soil pipe in the corner theres a water trap on the condensate pipe in the boiler
Drain or soakaway, drain has to be foul and not rainwater, unless its combined underground
There are many that don’t go where they should!
fit a strap on boss to the soil pipe
Are you wanting to do away with the drain its connected to now ?
Mine just goes through the wall onto paving slabs.
Easy to see if the PRV has gone.
Or is that a different drain we are on about?
Mine does point down 90 degrees.So does mine. British gas moaned one year that it should be pointing down not just outwards (along the wall), so I loosely popped a 90 yorkshire bend on it whilst he had his back turned.
That's different, op was talking about the condensate drain
just the ticket for limited room and solvent weld glueHere you go, this would work. I think a strapped version would be more secure though if you can get one in there.
https://www.tradepipes.co.uk/big-bo...X2rDBjwa7GdiXkg4X6061NXvnZJrqx9hoCTKwQAvD_BwE
