brightspark
- yarm stockton on tees
I noticed .and a few sparks off the toolnot much coolant used in that![]()
yea i know i picked up on that tooI noticed .and a few sparks off the tool![]()
)but lots of tooling nowadays is designed to run dry. The chips take the heat away and coolant can actually be bad for the tooling as you can get thermal fracturing.I only use coolant with hss drills.I noticed .and a few sparks off the tool![]()
Not watched the video yet (listening to Echoes and don't want to interrupt the magic)but lots of tooling nowadays is designed to run dry. The chips take the heat away and coolant can actually be bad for the tooling as you can get thermal fracturing.
we need a picture for proofAh that's nothing, done that on an old clapped out myford.![]()
too many tall stories on here to be believed
a couple of us started a tall stories posts on here people telling porkies it got deleted because some people were getting paranoid and thinking it was them
we need a picture for prooftoo many tall stories on here to be believed
You need to be working the inserts though or the coating doesn't work properly and they wear quick.I am exonerated then
Bob
whats the score with the final 1 thou cut thenYou need to be working the inserts though or the coating doesn't work properly and they wear quick.
man comes out with a filewhats the score with the final 1 thou cut then![]()
You don't need a final 1thou cut, the final 1mm DOC takes it exactly to size, no need to tickle thingswhats the score with the final 1 thou cut then![]()
You don't need a final 1thou cut, the final 1mm DOC takes it exactly to size, no need to tickle things![]()
You never did understand a clitorus im guessing.You don't need a final 1thou cut, the final 1mm DOC takes it exactly to size, no need to tickle things![]()
I don't use Carbide for thatYou never did understand a clitorus im guessing.![]()
I don't use Carbide for that![]()
