I've recently bought a 150l 14cfm air compressor which i'm using to run a couple of airtools in my shed, however i'm having a bit of a problem with the air pressure i think. It appears to be working fine in that it doesn't leak and it fills the tank fairly quickly.
However even with the pressure valve turned to max so its reading well over 100psi on the compressor and with the tool connected directly to the compressor, when i'm actually running the tool the pressure drops right down really quickly to about 2 bar and the tool really struggles to work (90 degree die sander, air ratchet etc) I have to use the tool in really quick sharp bursts so that the pressure is high enough at the tool.
Any ideas what i might be doing wrong?
