julianf
- devon, uk
Having some issues here that i can't resolve.
I've spoken on landrover forums, but, once the two adjustment options are repeated, suggestions run dry - im hoping people here may be able to help?
So, ive got this bulkhead -
Its going on this monstrosity -
(yes, i got it years ago, but have had a bit of a pause!)
Note - the outriggers have been replaced, and also the sills. But, the sills measure up, spot on, when compared to a stock vehicle (b-post to sill end), and the outriggers were done with some amount of care.
But...
So here is the foot -
You can put spacers in that gap (its not "spaced" nor tightened up in the photo), but the more spacers you put in, the tighter you close up the gap at the bottom of the door.
This gap -
Which isnt far off being right. Thats not my problem.
Also, the more spacers you put in, the closer you get to the sill. At some point you conflict. Im talking this part (but this photo is on the other side to all the others) -
My point is, you cant just keep adding spacers, otherwise you mess up the bottom door gap, but also have to shorten the sill! (and yes, its a fabricated sill, but its spot on dimensionally against a stock one)
So, you have the pivot point on the outrigger. If the outrigger was too far towards the front or the rear of the truck (ie if id put it on in the wrong place) then more or less spacers would be required. It shouldnt be a terminal error. Although if it were too high or low, im not sure. But i dont even know if thats possible, as the new outriggers wrap around the top of the chassis rails (ie locate height there) and also sit on top of a thick tie bar back to the chassis itself (that has not been altered) so locate there also. I mean, their height could be wrong, but i dont think its that likley. But, somthing IS wrong somwhere....
Because this is the top of the door -
Loads of overlap. The whole bulkhead needs to tilt forwards, toward the front of the vehical, to sort out that top door gap.
So, to recap, you have the fowards / back adjustment using the spacers on the foot / outrigger joint, and that seems set right (bottom door gap is fine), and this is also a pivot point.
...which is maintained by this bracket -
Which mounts to the footwells, and to the chassis.
The holes in the bracket are elongated, so as you can move the bracket forwards and back on the chassis rail. So you pull the footwell forwards, pivot on the A post feet, and alter the door gap at the top of the doors.
...except you dont. Or i dont.
At the full extent of travel on those brackets, pulling the footwells as far forwards as i can get them, even if i get a bar in between the A post foot and outrigger, and lever that joint open as far as i can (ie until the foot conflicts with the end of the sill) with a friend watching the b-post / door top gap, im not getting to where i need to be.
So, what now?
Sills could be too short - but theyre millimetre perfect when compared to the stock sill end to b post on my friends 90. (i understand 90 and 110 are otherwise different, but this part is the same)
Outriggers could be too high or low? If they were higher, all other things being equal, i think this would tilt the bulkhead the right way? But, again, they locate over the tops of the chassis rails. This is a photo of one -
The bit on the left goes over the chassis rail, and, indeed, the bit on the very very far left actually lips round to the inside of the chassis. You'd pretty much have to cut the whole thing about to try and get it to locate at an angle. Im not sure it would happen by chance?
(but, saying that, ive only tacked the outriggers on at present, as i wanted to be sure they were in the right place, so maybe there is flex, but im clutching at straws now!)
So this is a long post, but i wanted to go through all the detail. I dont really know what to do now?
Thank you.
But...
This gap -
So, what now?
Thank you.
