the snooper
getting older by the day
- Hull UK
Evening chaps anyone know of a supplier for a 240 primary 20-0-20 plus 12-0 15va secondary toroidal transformer
Thanks
Thanks
It's for a mixer and space is limited it's it's originally 2x115 v primary switchable voltage but the primarys have gonegot some big 240 to 12 volt transformers
They are like hen's teethI might have one let me check...
EDIT: All I got is these two.
thanks for looksGood link, don't have one but will enquire if it comes to it, thanksThere are people who can custom wind toroids for you. Try Airlink Transformers. Try RS or Farnell for off the shelf as their search engines work parametrically.
Have a couple of 0-20volt toroids if any good you can have for postage + a donation to air amb
Came out of Phillips talk through base stations that were scrapped
Thanks for the offer and uploading the picture much appreciated, unfortunately not what I need, I need centre tappedView attachment 214887 View attachment 214888
Have 4 of them 1 is made by St.Ives transformers now Carnhill toroidal it is marked VT30814
Yeah I knew that but as you can see in the picture space is tight, the removed transformer is sat on the larger one and fits into the space where you see the ventBear in mind that apart from the space required, you can use two transformers to give you a centre tapped output. I have a similar issue needing 12V negative and positive rails. What I have with a CT transformer is not good enough*, so have gone for a pair of 12V bare board SMPS which I will strap in series together and go straight to DC.
*Massive RFI issue which is a bit of a head scratcher.![]()
It's a 15va transformer with 20-0-20 & 12-0What sort of DC current is required? Those power supplies I ordered are 1.5A, but there are 2.5A versions. The boards are tiny, much smaller than the transformer.
What does that turn into, on the DC rails?It's a 15va transformer with 20-0-20 & 12-0
Not sure only just got this not looked that far other then one of the 115 primary coils are open circuitWhat does that turn into, on the DC rails?
