55 plate but I think the props are all the samewhat age?
I don't understand? From what I've seen on eurocargos they all seem to have the same spicer propshaft.No they are not.
TH white came unstuck with that idea.
Yes you will have different lengths of shafts to accommodate different wheelbases but the type of shafts are the same.All I know. In 2007 TH white damaged one, the thought they were the same, they looked the same.
It is something to do with gear box to support bearing and overall length.
They got the details by taking the VIN plate details to a Prop shaft site to get a replacement one.
Or 7 if you count mine nowWheel base (choice of 6)
I only need the slider stick out ,I don't need any propshaft lengths, it's ok I'll have a rough guess tomorrow, its 50/50 if it's rightyus, but lockdown.... and lorry is 15miles away.. plus its the Elwb version being a horsebox so probably no good anyway...
sorry![]()
2nd measurement and picture is what I needed , Thank youfront of prop into gearbox looks like a bolted flange, 0 stick out
centre hanger has a slider as pictured, 70mm stickout.
