daleyd
- Wrexham, North Wales
“Only”Got 160-180cfm air compressor got a twin fan air drier, and a spare desiccant system I was going to sell, what sort of power do they need I have 3 phase but only 100 amp
The water really reduces the distortion.Oh also the extractor fan as well as mine is downdraught because I didn't have time to make a water tray.
Having said that the downdraught is excellent and the only reason I would want water now is for the stainless as I actually fancy trying submerged cutting.
My whole setup runs from a 32Amp supply out to my container, that is Plasma, CNC controller (servo drives etc) compressor and lighting (although that is LED)
Distortion isn't normally an issue, what I fancy trying is fully submerged cutting, ie torch under the water as well, that should reduce the oxidisation on stainless.The water really reduces the distortion.
I will probably go LED for the workshop as the tubes die out, that is if I have not died myself by thenNicethats another thing on the list, lighting, I have 6 foot double lighting tubes all over the ceiling they are starting to flicker so on the way out, I am thinking of going LED next time, or as soon as it get to dark to work with the strip tubes
On thick stuff I suppose not but ha e you ever cut 1.5mm?Distortion isn't normally an issue, what I fancy trying is fully submerged cutting, ie torch under the water as well, that should reduce the oxidisation on stainless.
2mm stainless is the thinnest I have cut.On thick stuff I suppose not but ha e you ever cut 1.5mm?
I will probably go LED for the workshop as the tubes die out, that is if I have not died myself by then![]()
They sell them, I have them bookmarked but I have never tried them so can't say more than thatYou got me thinking now I wonder if its possible just to fit LED tubes in the old florescent fittings
You want the thermal arc type with a consumable starterSubmerged cutting does work and has lots of benefits. THC should still be fine as it is the arc voltage of the plasma machine and there has to be voltage whether under water or not, in fact I think the air likely causes a pocket under the water.
Where problems can arrise is with the torch itself, mine is a blowback ignition type torch so it has a moving electrode, I think that can get gummed up through time if used under water.
How does that work?You want the thermal arc type with a consumable starter
How does that work?
This is mine, have a spare head here so just took a vid. Basically the air pressure forces the centre bit up and that makes contact and starts the pilot arc.
It is not that clear but if you look at the centre bit it is moving as I pull on the braid at the back.
Mine has done way more than that and is still working. No doubt I will fire it up tomorrow and it wonthttps://www.rapidwelding.com/files/SL60 and SL100 Plasma Torch Operating Manual.pdf
You have a start cartridge. Last a few hundred to a 1000 starts if I remember.
