The small ones heavy. The big ones are seriously heavy.Just had a quick look on the net
http://www.lathes.co.uk/rapidor/img12.jpg
The lightweight version similar to we have is quoted at 280lbs, so 130kg roughly.
Taken from http://www.lathes.co.uk/rapidor/page2.html
"Advertised during the 1950s and 1960s this "Heavy-duty Production Hacksaw": was available in two sizes, the No. 1 with a capacity of 6 inches and weighing 438 Kg and the No. 1A with a capacity of 8 inches and weighing 508 kg. "
@jimbo84 - Do you have one found that you’re trying to collect or just asking to be prepared? Where are you up north, never know what and who is available
I use this method often.4 scaffie planks and a couple of scaffolding pole rollers . put 2 planks up to the trailer sit the saw on 2 of them and use rollers inbetween and push it up. no problem I have a diesel wacker plate and 2 people can pull it in no problem on rollers . 4 people couldn't lift it its heavier than a rapidor that has the cast base
The minor is a heavy little item.To clarify, all my comments are on the rapidor minor, not major.
As above, they are much heavier than they look!
I went out to pick up a "small one" and ready a lathe for transport next day, when my mate was going to help me. Thought I'd take the saw back with me that day but got as far as unbolting it from the stand and then almost killing myself trying to lift it off the stand - left it till there was two of us!
Also much easier if you do take it off the stand:
(lathe feet in the middle)
Ohh.... and if you do take the saw apart and lay it on its side prepare for the hydraulic oil to leak!
