Jonathan Webb
- West Sussex, England
Hello,
I need to make 10 x 1", 4 x 3/4" and 4 x 1/2" (or near metric equivalents 26,19 & 13 will do) in 10mm 316 stainless plate/bar. (in pieces vaguely the size of playing cards - they're load-spreading washers.)
I've come across Starrett CTD holesaws, which seem suitable but they don't go smaller than 15mm so only good for the larger sizes.
Dormer's A108 13mm stainless drilling bit is ca £45
I have a decent handheld drill, but was presuming to use my Tauco bench drill.
I could take them to an engineer - any chance 4 holes would be less than the cost of the drill bit? (FWIW, I've had quotes to laser/water cut the plates and they're £300ish, which is way outside my budget)
As a last resort, I wondered about the possibility of making rough holes with either my Javac Avalon 40 plasma cutter (hey, it works), or possibly arc gouging, then grinding out the resulting holes with dremel-type tool to 13mm. They won't be seen, so neatness isn't an issue, but function is. And this is a hobby, so time-cost doesn't come into it too much.
Ideally can anyone recommend a not-too expensive drill bit that will last for 4 holes (or 4 cheap ones?)
Many thanks.
Many thanks.
