roofman
Purveyor of fine English buckets and mops
- North West with water on 3 sides
was working perfect on mains 3 phase and then we moved to another address and wired it to a 50 KVA Genset and had it perfect for a day and now failure light is flashing..Have you confirmed the correct rotation direction if its new to you?
I can recommend The Compressor Man. http://www.compressorman.co.uk
going to have to call someone in it looks as we have work stacking up
nice thinkingIf you get desperate to get work out do you have a local plant hire company.
https://www.speedyservices.com/19_0070-h-silenced-road-compressor-diesel-twin-tool
Whenever I specify or fit a compressor I always have a tee and valve ready for standby or rental compressor to allow for a fast connection.
Its been working with the same blasters for a year in last address with no problem..in fact it has a 2 meter high stand up tank and with the blasters going it maintains 10 bar in the tank mate...belter of a machine but atm its got the fluI think your compressor probably can’t handle that duty cycle mate.
Constant run compressors that can handle that kind of CFM are not cheap.
See them in power stations all the time. Big buggers.
We run a road compressor for blasting. 140cfm.
Oil cooled.
