Lidl factor in that many won't bother or be able to comply with their terms. I bought a foot pump, thinking that'll never last 3 years. So when it failed after 6 months I took it back to the store with the receipt, like one does. No, no, I was instructed to email some address, so I did:
Good afternoon,
I purchased this pump last year on 13/03/2017. It came with a 3 year warranty.
The frame has come apart in normal use and it is not repairable.
Please advise me how I can get a refund.
Regards
a111r
Dear Mr M,
Re: Pump
Thank you for taking the time to contact us regarding the above product.
In order for us to assist you with a replacement unit, can you please provide the following:
· Your consent to pass your details to our supplier.
· Are you in possession of your itemised receipt? If so please provide us with a copy.
· The store you bought the item in
· The product cost
· Brand name and model number. These can normally be found on the product or within the instruction manual
· Serial number. This can normally be found on the product.
· Barcode number
· The IAN number (this can usually be found on the base of the product)
· Photographs of the faulty part and part number (where applicable)
· Your full postal address and contact telephone number
* In order to resolve your request, we require your consent to pass your details to our supplier so they can get in touch with you directly. As the manufacturer of the product, they’ll be able to offer you the best advice and support. For Data Protection reasons, we need your consent to do this. Please let us know if you consent with the transfer of your details by using the following text:
"I hereby agree to passing my details to the supplier."
If you do not give consent please advise accordingly.
Please note that your consent is voluntary. You can revoke your consent at any time by sending an email to customer.services@lidl.co.uk quoting your reference number.
Please note, if you have contacted us about more than one type of faulty product, these will be dealt with under separate reference numbers. Please respond to these individually.
Please send these details direct to the address below, quoting reference #3............... or reply directly to this email (without deleting the subject line):
Customer Service Department
Lidl UK
Tailend Farm
Deans Road
Livingston
EH54 8SE
I look forward to hearing from you.
Yours sincerely,
For and on behalf of Lidl UK GmbH
Only a 30 amp, presumably because of the pathetic 13A plug, while everyone else gets the 40 amp with a 16A plug... Worth it, 9mm cut in steel vs the 40A at 12mm? I'm in a quandary now
Realistically, would it do 10 / 12mm but slowly?
Dave H. (the other one)
Here in Italy someone achieved to cut through 15mm mild steel plate (severance cut)Any idea what thickness it will cut satisfactorily, also are the consumables easily obtainable. I wondered about one for the price, but my son is planning to get one dependant on the answers here.
Here in Italy Lidl soldWonder if they actually make 2 different versions or if its just a jumper on the inside that rescales the current pot, I notice that both pics are the same original but the scale and product code photo shopped on, I'd be happy to buy a 16A plug if a little setting change was all that was needed to get 40A
For £80, I'd suggest that anyone who doesn't have a plasma (and does have a compressor) should go get one!
We've talked on here many a time about taking a risk with ebay specials but at that price (and with the whiff of a 3 year warranty) it would be hard to say no.
You could fit a trafimet s45 on itI will be in tomorrow and buy one if I can, and I already have a Lincoln pro cut 25, with pilot arc,
The reason is the consumables, they are really expensive and difficult to source,
I was considering fitting a new torch from eBay with cheaper consumables, but it will cost about £80, so if I buy the Lidl one it’s the same cost,
And semi retire the Lincoln, using it only when the pilot arc is useful.
To adapt the original hose package to the s45 you can ask to your local machinist if he can make a brass coupling to adapt it
S45 torches are pilot arc and the consumables are cheap and easy to find
You can also get a Chinese copy
So who is going to be first to put a clamp meter around the return?well I have just called lidle and the guy said they are pps30 but he then said but on another page they are called pps 40 ? under the same lidle number
