Memmeddu
- Italia Sardegna
That's what I am supposed to use , but it's annoying every time expecially while I'm in hurry
Seems to be ok my kidneys seems to be okHope your peashooter bore is now clean and your kidneys feel better .
When I was in hospital many years ago having my appendix out, there was a man in there that had a nasty accident. He was having a pee with a shotgun under his arm when it went off, he was lucky, he only caught a odd few stray pellets, but the nurses reckoned it was like a garden watering can rose went he went.They asked me if I ever been shot with a 12 gauge
Narrator; This set did not leak.give me your full address and I will catch the sink before it hits the deck![]()
YET!!!!!!!!!!!!!!!!!!!!!!!!!!
Yesterday here a man being killed by 12G buckshot fired at 170 meters distance while boar huntingWhen I was in hospital many years ago having my appendix out, there was a man in there that had a nasty accident. He was having a pee with a shotgun under his arm when it went off, he was lucky, he only caught a odd few stray pellets, but the nurses reckoned it was like a garden watering can rose went he went.
No way on gods earth someone was killed with a shotgun full of shot from 175m. Not even 100m.Yesterday here a man being killed by 12G buckshot fired at 170 meters distance while boar hunting
Buckshot is not legally allowed here
Shotguns can use slugs and small pellets
Rifles can use soft point rounds only ,no full metal jacket allowed
To prevent accident
Another guy this morning shot itself with his shotgun while jumping an obstacle , same spot the arm ,if was using buckshot his arm could be cut off
So small ones then? I have them both sides and go in May 22 for slice & dice, they are going through the back on one side because they are apparently 3cm for the other side they will go in from below! Again!Seems to be ok my kidneys seems to be ok
But magnetic resonance has shown 5 or 7 stones that are about 9mm in the right kidney
And various probably 15 about the size of a pellet so 4 to 7mm on the left one
Maybe a decimal point required on that oneNo way on gods earth someone was killed with a shotgun full of shot from 175m. Not even 100m.
Sounds strange but considering that he is being hit at the femoral artery by a single pelletNo way on gods earth someone was killed with a shotgun full of shot from 175m. Not even 100m.
Sorry to read about , because I know what does mean that pain.So small ones then? I have them both sides and go in May 22 for slice & dice, they are going through the back on one side because they are apparently 3cm for the other side they will go in from below! Again!
I am not a fan of the blue and red crimp on connectors. I expect the ones I used in my youth were cheap and nasty. I still prefer to use brass terminals, crimped and soldered.
Peter
Did they tell you about the reasons or what makes you produce stones?
Yesterday my tool was on fire
I've always called them Bodgers' Crimps. Brass crimped (not soldered) with the clear PVC boots, at least you can inspect them.
Dave H. (the other one)
To be honest not too much was practically already out
Yesterday my tool was on fire for the pain all day long , blood .
This morning no pain , toilet little bit of pain ,bad words to God and nothing more ,and just just little bit of blood
Hope that the others will be similar to this
Unfortunately I did not stick my hands in the WC to recover the stone because I won't do that
So if I will kick out another one I will be more careful to not lose it
70s Citroens used two fan belts and two hydraulic pump belts. You would hope if you bought two 975mm belts they would be the same, unfortunately not. So I made this thing today. Put both belts on and pull the sliding block. You can then see if they are both the same length. I had six belts in stock, four have made matched pairs, the other two will come in handy one day.View attachment 209608
It's very painfulDaughter has them every year or two, kidney damage as a kid, she has calcium citrate fizzy tablets prescribed to help prevent them
I've had two in my life, still remember them pinging in the pan and the pain in the pinging...
