I've never towed anything (or needed to)
But mines fitted with a NATO hitch, I'm guessing it's better than these tow ball things?
Not all NATO hitches are type approved.
I just wrap it round the ball.......to be honest I feel it would be better with a seperate attachment (in case the ball breaks)......Im one of the old school....proper tow ball for me, Alko type for the caravan....dont like, dont trust the swan necks, folders or detachable.
its not long enoughRound the back of the flange would be better.
its not long enough
Only legal in the UK on sub 1500kg trailers.
.The car is 17 reg.....not 3 years old yet....its the cable thats short.....the caravan is 12 years old this year......I think I remember that the cable dragged on the ground so I shortened it but at the time the car had a pigtail to connect it to.......Im getting a new car before I will tow again so I might treat it to a pigtail...or get a new cableNormally they are too long.
What age is the car?
There is a LR recall to test your removable hitch, if it fails or you tow big loads they replace it with a fixed tow bar
Always use the factory recovery eye on the rear of my D3 to attach the breakaway cabke
To the letter of the law using a shackle is not type approved.
How old is the car? If post 2014 then it must have a tested attachment point for the cable.
However they often just use a hole that the new style clip fits but the old style does not.
Looping the ball only should only happen if no better place exists.
On all post 2014 vehicles there must be a proper place, on all flanged balls there is a better place behind the flange.
At some point it will. Thats the point.
It’ll be fine, make sure if it’s a rotating hitch that it’s locked when using a rotating eye, or else they turn upside downI've never towed anything (or needed to)
sadly last year somone was killed when a trailer came loose from a pickup and hit there car, apparently everything was checked thoroughly by police and vosa , out come was it was due to a bump in the road , no one charged.
Some interesting information in this thread. Had no idea that having a trailer come away was anything other than a super rare occurrence. I always refer to the USA made towbar setup on my truck as "the full hillbilly" it's mostly made of 1/4" and 3/8" plate, I had to use a couple of jacks to lift it up into position after blasting and repainting it. I occasionally tow a loaded car transporter trailer on this setup, The jacking up the rear on the jockey wheel hitch test sounds like a good idea.
I'd respectfully suggest that you check the source of that gem of information.
Trailers exceeding 750 kg's are legally required to be fitted with brakes, activated by a breakaway cable in the event of the towball, (not the towbar), becoming detached from the towing vehicle. I can fairly well imagine what the boys and girls of the DVSA would say if they came across a heavy enough wobble box connected to a vehicle with chains.
LOL your are really going to argue with me over trailer law.
I suggest that you read the Trailer IVA guide re brakeaway & secondary couplings & then come back.
It seems to me all the trailer IVA cares about is meeting specifications - just like Grenfell. Whether or not the brakes actually work doesn't seem to matter - unless they have changed it since I looked into it about 2 years ago.
