F fizzy Member Messages 14,002 Jan 5, 2020 #1 Hose clips. Look crimped on or something. Any easy way before I wreck them?
Ashley Burton Member Messages 5,070 Location Northamptonhire Jan 5, 2020 #2 Flat blade screwdriver through the crimped part to release
ajlelectronics Forum Supporter Messages 11,303 Location Gloucester, England Jan 5, 2020 #3 https://www.ebay.co.uk/itm/US-PRO-C...Pliers-Angle-CV-Drive-Shaft-1823/292718463229
stuvy Member Messages 9,202 Jan 5, 2020 #4 Ashley Burton said: Flat blade screwdriver through the crimped part to release Click to expand... This then replace with a jubilee clip
Ashley Burton Member Messages 5,070 Location Northamptonhire Jan 5, 2020 #5 ajlelectronics said: https://www.ebay.co.uk/itm/US-PRO-C...Pliers-Angle-CV-Drive-Shaft-1823/292718463229 Click to expand... They don't look the same type of clips that I use these type of pliers for
8ob Member Messages 14,382 Location Nescient in the vale Jan 5, 2020 #6 They are the Oetiker stepless clips. Just need the right pliers. Bob
Ashley Burton Member Messages 5,070 Location Northamptonhire Jan 5, 2020 #7 I've started using Mikalor hose clamps in recent times!
8ob Member Messages 14,382 Location Nescient in the vale Jan 5, 2020 #8 To remove just knock up the tab and pop off with a screw driver.
F fizzy Member Messages 14,002 Jan 6, 2020 #10 Managed to mangle the horrible things off. Jubilee clips going back on assuming Pirtek have the right connectors in stock. What is the most common on modern torches?
S selectedgrub Member Messages 3,613 Location New Zealand Jan 7, 2020 #13 You rest the other side of the special pliers on the ear, 1 jaw on the top and one on the bottom. It cuts through, holds and removes the clip.
