seriesonewelder
- West Midlands
a few questions so I can be prepared for an electrician to give a quote.
I want to fit a consumer unit in my garage serving the garage/outside lights/sockets only.
The main electric feed cable enters a 'cupboard' at the side of the front door (see pic) and feeds into the house CU in the kitchen the other side of the wall.
From reading other threads I understand I can take a cable from the unit on the far right (cover removed for pic) of the pic (splitting the tails?).
The distance to the new CU is no more than 10m. I want to use armoured cable and route it around the outside of the house, and into the garage which is under the house.
What size cable should I use allowing for a
32amp ring,
2x 16amp sockets,
6amp internal lighting
how do I factor in outside power sockets (x2 doubles) and outdoor lights (alow 6amps?), do they have to be on a seperate circuit/radial?
Thanks
32amp ring,
2x 16amp sockets,
Thanks
due to it being designed for singles meter tails. best bet and if it was me i would try and go from your house consumer unit, but that could involve some tricky work with concealing the cablebut im sure someone with a better idea will come along soon
