Spark plug
- Durham, England
Your a bad influence you lot, got me spending money again
do it for 45 years and you rarely buy stuff unless its at give away pricesYour a bad influence you lot, got me spending money again![]()
even then do you realy need it
. I call that a set of burrs....not a tool. Lol . I was hoping it was one like Double Boost uses.
good manDrill bits, open ended spanner set, scriber and a deburring tool ordered![]()
https://www.cromwell.co.uk/shop/cut...ce-select-a-drill-set-1-10-00mm/p/ITD0254320WAlmost fell for the drill bits till i found them £5 cheaper at Zoro... https://www.zoro.co.uk/shop/cutting...et-1-0-13-0mm-x-0-5mm-metal-case/p/ZT1132698X those before and afters do look tempting!
Yeah I really should know better.....Almost fell for the drill bits till i found them £5 cheaper at Zoro... https://www.zoro.co.uk/shop/cutting...et-1-0-13-0mm-x-0-5mm-metal-case/p/ZT1132698X those before and afters do look tempting!
If your ordering £40 or more of stuff it might be worth splitting your order into two £20 orders. I received a 20% off voucher to use against my next order which I could have used straight away![]()
Happens all the time here.![]()
, Must be a foreigner, you will be extradited
Spending money in Scotland John ?, Must be a foreigner, you will be extradited
Bob
me too SlimI've had an email confirming my order has been despatched.![]()
