The_Yellow_Ardvark
https://www.death-clock.org/
- Going Away.
As some of you know the above lather motor has failed.
Cracked casing.
Not sure how that happened, but it has.
The motor details are.
Hoover AC Motor.
HP. 1/2
Rating. Cont.
Type. 129G.B.F.
Volts. 230/240.
Cycles. 50.
Phase. 1.
Amps.3.39.
RPM. 1425.
No. 7.29308
The O/P shaft is 0.5" Dia and 1.5" long, with a machine flat to tighten a grub screw on to.
Does anyone know of a place local to Wiltshire who could supply a suitable replacement?
Thanks in advance.
Cracked casing.
Hoover AC Motor.
HP. 1/2
Rating. Cont.
Type. 129G.B.F.
Volts. 230/240.
Cycles. 50.
Phase. 1.
Amps.3.39.
RPM. 1425.
No. 7.29308
Thanks in advance.
I have a few machines with flats and grubscrews that take some stick my 3hp compressor is one . just thought on the myford countershaft only has a flat on the shaft with a grubscrew in the pulley
