- Birmingham
Would I be right in thinking that the trunking must be metal too then??
There are clips designed to retain the cables inside the trunking @brightspark will probably give a better answer as he's more up to date.
At my Son's school I found a curly lead made by the teacher with a 13 amp plug at each end that the kids had been using to daisy chain the electrics of the desks using the sockets attached to the desks!!!!!! Worst thing, it had a PAT test label for that very day on each plug!!! The headmistress went mad when I showed her the possible fatal consequences.
https://www.google.co.uk/search?ei=...6ezlAhXSYcAKHZjJB4QQ4dUDCAo#spf=1573841670530It wouldn't be today, but if it complied with the Regs in force at the time it was installed you cannot apply the Regs retrospectively, unless you make substantial changes to the circuit or installation. There must still be 100s of thousands of old Wylex fuse boards, with re-wireable fuses, still in service across the country.Thinking of electrical safety rules/regs, is there any situation where you can use these clips on mains cable nowadays? When I moved 4 years ago the estate agent said that they were not acceptable when he saw them/cable runs in my garage, he said that all cables must be inside conduit now? Is that correct??
It won't be just the torch that might spit fire with a fuse like that.This was only about a month ago, brand new cut 50 plasma. Apparently standard to find with these quality machines![]()
May have machined a fuse from copper earlier in the year.View attachment 201072
I've seen a few photos of "soldered in copper wire to replace fuse"
I'm always impressed they managed to heat the plug terminals up enough to get the solder to flow/stick without melting the plug at all
unless the plug is a bit melted and I just can't see it in the photos?
Obviously lii informed amateurs, isn't the correct procedure to drill through the 13a fuse lengthways, pass a length of 15a fuse wire through then a blob of solder to each fuse end cap.![]()
