Hi all another newbie with probably the same old questions!!
Machine Mart have a sale on this weekend, 17 ½% on Clarke’s welding kit (if you have an invite) and I had intended to buy a 175TEC Mig welder.
However, after a few conversations with people, I am completely confused!
I need a welder for mods to a carbon steel motorcycle frame. Budget Max £350. Welding probably a max of 5mm plate but mostly thinner than that.
Its 25 years since I last welded at college, but I had a go on a MIG set a number of years ago and it seemed easier than Arc.
I have now been advised that a 140 amp Arc welder would be far better (£80!) I’m not sure if 140 Amps on an Arc welder equates to welding the same thickness on a Mig Welder.
Then someone else has advised to go for an Arc/Tig Invertor. Looking at the Machine Mart catalogue, I could run to £350 max so could afford a TIG155. Reading the blurb, it works as an Arc welder at 140 amps.
I can get Argon/Co2/Argonshield, gloves, shield etc via work as we also do welding. I can’t source a welding set in my price range cheaper via work!
So, Mig, Arc, Arc/Tig Invertor??
Cheers
Gary
http://www.aircooledrdclub.co.uk/forum/
Cheers
Gary
