123hotchef
- Kent
If ta an early dynasty they had some issues with the HF board.
Torch wise does the Hf improve if you touch the tungsten to the work then arc up?
i think this has a board of electronic gismosI dont know about your welder but some have a points gap inside for the HF
If yours has you might want to clean up the ends and check/adjust the gap
Yep that’s certainly enough to reck em.Mine has Hf issues. Only slight no where near as bad as that but I’m 90% sure it’s because I’ve run the torch without remembering to turn the cooler on.
