M1CDQ
Ive got a load of old sifsteel welding rods.what I want to try and do is make some small candle holders with it but trying to weld the stuff together with a smaller dia welding rod all i end up doing is melting the lot.Ive even got the tig down to 10 amps.
I am asuming I need a different filler that has a lower melt point.I did try soldering it using a small plubers blow torch but its conduting the heat so must that the prev joint is melting.I have even used some grips to heat sink between the joins but that fails as well
