just starting to get the workshop fitted out and i decided to test the mig as im going to be needing it soon as its been in storage for best part of 6 months.
problem is that when i pull the trigger i hear it click in and come to life but after a few pulls on the trigger the m.c.b trips out in the consumer unit, the welder is on its own dedicated 16A C type M.C.B fed to a 25A rotary isolator switch then to a 16A ''blue'' stile socket on the wall.
welder:-
cheap nasty bought before i discovered this place Cosmo 170
so any ideas on this, could it be a surge on start up even though nothing is being welded?
help please
welder:-
help please
2.5mm T&E running in 20mm conduit tot he CU and on a 16A tpe C MCB but i do remeber trying to run it on full chatt last time it was blowing a 16A so i think i needs a bit more juice
iv bough a 20A type B to try and a 32A type c if it works on the 20A then ill leave it as that if not then ill upgrade to to 32A gear
and i sall be boxing the pipes in to protect them
