Bad choice it will rot through
A lot of modern designer radiators are aluminium, most of them on the continent are as well
Customer just had a load £800 each nothing special.
Why would it rot through?Bad choice it will rot through
I try to spec them these days as they are much lighter but costly as you have seen
Well I could be wrong.
But high temperatures and a corrosive environment with low levels of oxygen would worry me.
You’d need to find the right alloy.
Can’t help you any more than that.
Yes easier to fit and man handle.
Fitter couldn't work out how to measure for the four separate brackets.
Are all trades full of idiots?
Most of the drive components in marine applications are aluminium. eg jet ski jet pumps, engine ect. These are subjected to heat, saltwater ect.
All in the presence of oxygen.
Aluminium is highly resistant against salt water corrosion.
Wouldn't the presence of oxygen speed up corrosion? (Oxidation)
It's the presence of oxygen that gives aluminium its corrosion resistance. Oxygen reacts with the aluminium and creates an oxide layer.
If you look at any galvanic series table, Aluminium should corrode sacrificially to Iron....in practice it doesnt because the Oxide forms on the Aluminium surface and protects the Aluminium. I think that the presence of Iron in the water can interfere with the Oxidation process and reduce its effectiveness but Im not sure how severe this is....I suspect, not very, because otherwise we would be hearing of the issues.It's the presence of oxygen that gives aluminium its corrosion resistance. Oxygen reacts with the aluminium and creates an oxide layer.
