123hotchef
- Kent
Did you have a flag on that??? Wouldn’t be much to see from behind!
To answer the question you could look up the structural data for 9mm steel with whatever span between the existing table supports and work out the span required for the same stiffness in 6mm. Is the 6mm going to be plonked on top of the current 9mm? That would complicate things!
if you did make a steel sandwich, would you be planning on a few well placed spot or plug welds to stop it rattling like an old tin shed?
Aha. Ok sorry edited my post as you “liked” it.
Is the old school table all metal?
Sounds perfectly respectable to me, I have a lot of odd bits of metal resting on chunky wood. I moderate my use of it accordingly and don’t weld fixtures and fittings to the top for obvious reasons.
Just wondering what the forum thinks about glueing it down with some silicone or some other heat resisting filler? Once you have a table it does tend to get used for all sorts of things apart from welding so stopping it from rattling or shifting about would be one of my concerns for such a big one.
I can drill some holes and bolt it through the table frame with nice counter sunk hex head bolts wont need many
Completely off topic, can you get me some measurements of that front bumper please? Been looking to make one so I can add a winch etc to my pick up. Not paying daft prices they want on eBay for one though!!
Sure pm me what measurments u need and I will.get the rule out
Back on topic..my tables have all been 6mm, chuck some bracing under it and it’ll be fine. Have one with a 10mm top that gets used for beating and FIL’s overflow storage![]()
